I have yet to install everything in my case. Installed W10Pro from USB, activated, works fine. Boot drive is an Adata 1 tb 8200 Pro NVMe. EVGA 1070
Problem: Very slow to boot...once up and running, the few benchmarks that I've run seem adequate. Crystal Disk Mark speeds OK, but userbenchmark SSD result was very poor....
Bigger issue is that I can't access the BIOS. Have tried several times. PC eventually boots to Windows after at least a minute.
Only mistake I'm aware of that could be a problem is this: I unmounted the USB drive that W 10 was on, instead of going into the BIOS to change the boot order, and then removing the thumb drive.
This isn't the first PC I've built. Seems I always run into an issue or three that stump me.....
Thanks for any advice.
