agrikk
- Apr 16, 2002
Here's my setup:
I am trying to enable client VPN from the internet using PPTP to allow them access to resources on VLAN2 but I am having problems making it work. If I connect a machine directly to VLAN1, bypassing the router, I get a VPN connection as easy as you please, so the Windows machine is set up correctly.
However, if I try to connect from the internet (from a Windows XP machine) I receive a "Error 721: The remote client did not respond" error message. Clearly the router is not forwarding things correctly, but I can't figure out what.
Here is the router config:
I added the "ip nat inside source static 10.1.0.10 99.99.99.100" command to try to forward all ports to the VPN server, but even that doesn't work. I can ping hosts on the internet from VLAN2, and I can ping the windows server interface on VLAN1 from the internet so routing is set up properly.
I'm missing something.
Here's the results of show ip nat transaltions:
The x.y.z.241 address is the internet-showing interface on my Linksys firewall. The connections on port 53 are connections to DNS servers.
I understand that to make PPTP work I need to open port TCP 1723 and allow GRE (protocol 47), but wouldn't ip nat inside source static 10.1.0.10 99.99.99.100 allow everything through?
The maddening thing is that I had it working when I would forward everything to the VLAN1 interface on the windows server, but then I powered off my router and now it doesn't work anymore, so I must have lost a configuration somewhere.
Code:
Lightning#sho run
Building configuration...
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
no service password-encryption
hostname Lightning
[stuff removed]
ip subnet-zero
process-max-time 200
interface Ethernet0/0
description Inside Interface
ip address 10.1.0.1 255.255.255.0
ip directed-broadcast
ip nat inside
interface Ethernet1/0
description Outside Interface
ip address 99.99.99.100 255.255.255.0
ip nat outside
ip nat pool mypool 99.99.99.100 99.99.99.100 prefix-length 30
ip nat inside source list 1 pool mypool overload
ip nat inside source static tcp 10.1.0.10 1723 99.99.99.100 1723 extendable
ip classless
ip route 0.0.0.0 0.0.0.0 99.99.99.1
no ip http server
access-list 1 permit 10.0.0.0 0.255.255.255
[stuff removed]
no scheduler allocate
end
Code:
Lightning#sho ip nat translations
Pro Inside global Inside local Outside local Outside global
udp 99.99.99.100:2996 10.1.0.10:2996 192.175.48.1:53 192.175.48.1:53
udp 99.99.99.100:3000 10.1.0.10:3000 192.175.48.1:53 192.175.48.1:53
udp 99.99.99.100:3005 10.1.0.10:3005 192.175.48.1:53 192.175.48.1:53
udp 99.99.99.100:3009 10.1.0.10:3009 192.175.48.1:53 192.175.48.1:53
tcp 99.99.99.100:1723 10.1.0.10:1723 x.y.z.241:1478 x.y.z.241:1478
udp 99.99.99.100:1038 10.1.0.10:1038 192.175.48.42:53 192.175.48.42:53
tcp 99.99.99.100:1723 10.1.0.10:1723 --- ---
udp 99.99.99.100:1038 10.1.0.10:1038 192.0.34.126:53 192.0.34.126:53
--- 99.99.99.100 10.1.0.10 --- ---
