help with java array
syn3rgyz
so my professor gave me this class
Code:
import java.util.Scanner;
public class ABStack // Array-based implementation of a stack data structure
	//instance variables
    int [] pile; // This array holds the contents of the stack. The stack grows rightward from element 0.
    int count; // # of elements in stack. This value is also the index of the next available array element.
    public ABStack(int size) //constructor
		if(size > 1)
		    pile = new int[size];
		else
		    pile = new int[1];
		count = 0;
    public boolean isEmpty()
		return(count==0);
    public boolean isFull()
		return(count==pile.length);
    public int size()
		return count;
	// Add a new value to the top of the stack.
	// Do nothing if the stack is full.
    public void push(int n)
		//add n to stack top
		if(!isFull()) //have room
	    	pile[count]=n;
	    	count++;
	// Remove (and return) the value on the top of the stack.
	// If the stack is empty, return -99999 as a sentinel value.
    public int pop()
		if(isEmpty())
		    return -99999;
		else
		    count--;
		    return pile[count];
im trying to call the methods the code i have so far is
Code:
import java.util.*; // Needed for the Scanner class
public class lab12
	public static void main(String[] args)
		Scanner sc = new Scanner(System.in);
		System.out.println("enter an expression in postfix notation");
		String something = sc.nextLine();
		char[] expression = something.toCharArray();
		ABStack stack = new ABStack(expression.length);
		for(int i = 0; i < expression.length; i++)
			int op1 = 0;
			int op2 = 0;
			if (expression[i] == '+')
				op2 = stack[stack.length-1]
i thought i used to constructor ABStack to create a new array with the length of 'expression' but i cant call the stack it claims its not an array. help plz?
*edit
now i tried calling the push method and it says its undefined too
Code:
public class lab12
			int op1 = 0;
			int op2 = 0;
			if (expression[i] != '+' && expression[i]!= '-' && expression[i] != '*' && expression[i] != '/')
				push(expression[i]);
thanks, but now i got another problem... so basically im trying to make the program understand 33+ as 3 + 3 and 32* as 3 * 2 etc..
my code is now
Code:
public class lab12
		if (stack.count != 1)
			int op1 = 0;
			int op2 = 0;
			if(expression[i] == '+')
				op2 = stack.pop();
				op1 = stack.pop();
				stack.push(op1 + op2);
			else if(expression[i] == '-')
				op2 = stack.pop();
				op1 = stack.pop();
				stack.push(op1 - op2);
			else if(expression[i] == '*')
				op2 = stack.pop();
				op1 = stack.pop();
				stack.push(op1 * op2);
			else if(expression[i] == '/')
				op2 = stack.pop();
				op1 = stack.pop();
				stack.push(op1 / op2);
			else
				stack.push(expression[i]);
		else
			System.out.print(stack.pop());
but i keep getting the wrong numbers as output i totally dont see whats wrong
OMG>>>!! how did i not see that... thanks,
but how do i convert back from char to int?
Subtract character '0' from the character you want to convert. For example:
Code:
int r = '6' - '0';
r would now be the integer 6.
thanks for the replies i asked my TA for help and even he cant tell why my numbers keep comming out wrong. all he knows is somehow the numbers are in ascii code
so have you tried implementing JasonE4's suggestion yet?
there's also an "Integer.valueOf(char)" function i believe
yep i tried jasons method and still no good
and my TA tried the method you mentioned and others too.
my professor said hes gonna exempt this lab and hes going to post a sample solution
