Help with finding a fanless 12 port switch
J-Will
I am currently using a Dell PowerConnect 2824 at home, and while it works just fine I am looking to replace it for something around the same physical size (or smaller) but fan-less. Management is not necessary for the replacement switch, though I would like it to be able to pass through POE from another switch. With this relocation project I wont need as many ports.
12+ ports
fan-less
POE pass through
smaller than 1.65" x 13.00" x 9.10"
Cmustang87
I don't know of any switches that meet this criteria and also be fanless. Hopefully someone else has something for you.
J-Will
Thanks. finding fanless with a decent number of ports is pretty difficult
Cmustang87
Zyxel makes a 16 port fanless switch, but I don't know if it is POE passthrough. Their website is having issues at the moment.
J-Will
I'll check them out.
Pass through might not be the correct term. I dont want POE supplied from another switch to be stripped out when it hits this switch. I dont need this switch to actually supply the power to the POE device.
Aluminum
Strong odds DNE.
Pass through switches are almost always designed to be a power source themselves, PoE and fanless generally don't happen together. Physics and all that ;)
D
Deleted member 12106
Guest
If you want POE passthrough, that sounds more like a Ubiquiti type switch. There are plenty of dumb switches which are fanless and even smaller than that power connect.
J-Will
I just want one that wont kill a POE source from reaching its target. This switch will be between the POE switch and POE devices.
I though some switches could 'relay' POE instead of the typical 'stop it'
