Help with desk issue.
bandit390
My glass desk was attached to a metal piece by glue/whatever and the metal piece screws into the support bar, but the metal piece has come loose from the glass. See the below picture. What super duty strong clear substance can I buy to attach this back?
Broken
The correct way
bigddybn
If you can remove the piece completely do that, clear all of the old adhesive, rough up the glass and metal contact surfaces with some sandpaper, apply 2 part epoxy and let it cure.
