I'm trying to figure out an elegant way to make navigation for my website. Currently I have it working using a piece of an old thing I did a few years back. The old way uses tables, not stylesheets.
old way
new way
Is there a way to get the stylesheet to place the links with gaps between then without using tables? Or should I use less tables then the old one, and specify the width of each row in the stylesheet? Another problem with the new one is the gap above and below the text.
old way
new way
