We were running a virtual machine with the LAMP stack. We had a weird issue that took down the host. Upon restarting everything, the ubuntu machine we were running the LAMP stack on detected a corrupt disk. I restarted it and it attempted recovery. Upon bootup though, mysql will not run.
The log file under /var/log/mysql has references like this to innodb:
InnoDB: End of page dump
160215 12:03:33 InnoDB: Page checksum 2005497002, prior-to-4.0.14-form checksum 1694579326
InnoDB: stored checksum 2005497002, prior-to-4.0.14-form stored checksum 384041447
InnoDB: Page lsn 1 1892569141, low 4 bytes of lsn at page end 1892678687
InnoDB: Page number (if stored to page already) 642,
InnoDB: space id (if created with >= MySQL-4.1.1 and stored already) 0
InnoDB: Page may be an insert undo log page
InnoDB: Database page corruption on disk or a failed
InnoDB: file read of page 642.
InnoDB: You may have to recover from a backup.
InnoDB: It is also possible that your operating
InnoDB: system has corrupted its own file cache
InnoDB: and rebooting your computer removes the
InnoDB: error.
InnoDB: If the corrupt page is an index page
InnoDB: you can also try to fix the corruption
InnoDB: by dumping, dropping, and reimporting
InnoDB: the corrupt table. You can use CHECK
InnoDB: TABLE to scan your table for corruption.
InnoDB: See also MySQL :: MySQL 5.5 Reference Manual :: 14.20.2 Forcing InnoDB Recovery
InnoDB: about forcing recovery.
InnoDB: Ending processing because of a corrupt database page.
160215 12:03:33 InnoDB: Assertion failure in thread 139736657061760 in file buf0buf.c line 3623
InnoDB: We intentionally generate a memory trap.
InnoDB: Submit a detailed bug report to MySQL Bugs.
InnoDB: If you get repeated assertion failures or crashes, even
InnoDB: immediately after the mysqld startup, there may be
InnoDB: corruption in the InnoDB tablespace. Please refer to
InnoDB: MySQL :: MySQL 5.5 Reference Manual :: 14.20.2 Forcing InnoDB Recovery
Anyone willing to help me step by step trying to recover this data? I'm currently imaging everything over so I can try this in a test environment. Backup is too old to be useful.
Thanks!
InnoDB: error.
Thanks!
