runningincircles
- Jun 25, 2001
Hi All
I recently received a couple t1000's that I intend to use to connect to a win2k3 terminal server. They have windows CE on them currently and are preconfigured to connect to the old company's internal citrix network. Whe nI power them on all it will do is:
-try to connect
-fail
-runs ping test
-attempts to login again
Is there any way to bypass the startup and reconfigure the default connection type and server location? I can find very limited information on these and have no experience with windows CE. Can any of you point me in a good direction?
Thanks!!
-try to connect
-fail
-runs ping test
Thanks!!
