imgneevrythng
- Jun 5, 2008
Hello everyone. I've used these forums in the past for PC help, and you guys have never failed me. So today I'm asking for you guys to help me put together a new PC build. I won't be purchasing the parts until after the holidays, but want to get a head-start so I know what I'm getting myself into and I know what kind of deals to look out for.
So here goes:
Mostly gaming, however I work as a designer and use Adobe Illustrator as well as 3D software like Solidworks, so it would be nice to be able to take work home with me.
Budget as of right now is $700 max, shipping and tax included
USA, more specifically New Jersey
I'm going to need a new case, cpu, motherboard, ram, power supply, and would like to have an SSD.
I purchased a Radeon 6870 last October, so I would like to use that for the time being. I also already have a harddrive and CD drive I could use.
6) Will you be overclocking?
Nope
21in 1680x1050. This I plan on upgrading around February, so it is not included in the budget.
I plan on building the PC myself.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
TBH I'm not really sure exactly what I would need, as I've never really used features like RAID before, but I might and I would like to have the best motherboard possible while staying within budget.
WIndows 7 64bit
So here goes:
Nope
WIndows 7 64bit
