I have a rig with a xfx 5870 xxx edition. I cannot get it to do any more than 157 khash without getting errors or crashing.
If I leave out thread concurrency I can only set intensity to 11 or I will get errors. If I set tread concurrency it will get 300 khash but will eventually crash after a day or so.
Running cgminer 3-7-2. This is one of my bat files that crashes. cgminer -o stratum+tcp://useast.wafflepool.com:3333 -u 1B56qD1mVdkJJApjRCdZdXdGz8WKUyDqwg -p d=128 -I 12 --scrypt -w 256 --thread-concurrency 5600
Does that look ok?
This is only bat file I can get to work. cgminer -o stratum+tcp://useast.wafflepool.com:3333 -u 1B56qD1mVdkJJApjRCdZdXdGz8WKUyDqwg -p d=512 -I 11 --scrypt
Tried reformatting,changing clock speeds,running latest driver and tried beta driver,tried a bunch of thread concurrences or adding shader count instead. I have same problem on middlecoin.
This is the rig I am running. Z77 Extreme6 ,i5 3570K,Antec NEO ECO 620C power supply and 16 gb ram.
Anything else I can try? Been messing with this rig off and on for months. I am at a dead end.
Does that look ok?
