Help with an Excel Formula?
noobman
Hey all,
I need to create a nested if statement for Excel.
This is what it would look like in a normal programming language:
Code:
if (orders < 500)
	cost=20;
else if (orders >= 500 && < 1000)
	cost=18;
else if (orders >= 1000 && < 1500)
	cost=16;
else if (orders >= 1500 && < 2000)
	cost=14;
else if (orders >= 2000 && < 4000)
	cost=13;
else if (orders >= 4000 && < 6000)
	cost=12;
else if (orders >= 6000 && < 7000)
	cost=12;
I've been wracking my brain on this with no results. Help?
Pwyl_The_Destroyer
=IF(A1<500,20,(IF(A1<1000,18,IF(A1<1500,16,IF(A1<2000,14,IF(A1<4000,13,IF(A1<6000,12,IF(A1<7000,12))))))))
Should get you started
the general form is:
Code:
=if(condition_criteria, value_if_true, value_if_false)
and you can nest any functions you want in any parameter as Pwyl_The_Destroyer has demonstrated.
heatlesssun
Extremely [H]
You might want to investigate Excel array formulas. Just search on it, they very useful for this type of logic.
mikeblas
[H]ard|DCer of the Month - May 2006
I'd use the lookup functions; you can find the first item within a range, then get the values associated with that range. Once it's hooked up, you can just edit the reference table to change the values around.
rayman2k2
=IF(H31<7000,IF(H31<=6000,IF(H31<=4000,IF(H31<=2000,IF(H31<=1500,IF(H31<=1000,IF(H31<500,20),18),16),14),13),12),12)
That may not be fully accurate, but the general gist, take a look and see if you can figure out what I did there.
Pwyl_The_Destroyer
Ahh... inexact match... excellent!
Much better than doing nested if statements.
bonsai
I'd setup a reference table and use vlookup to find the values. That way if your ranges and/or prices change you only have to update them in one place, not every cell. Also other tables will be able to access the same reference values.
Check out: http://contextures.com/xlFunctions02.html under Create a VLookup formula for a range of values
zaxour
You may want to consider doing some macros using simple Visual Basic (hit alt-F11):
Right Click on "VBAProject(Filename.xls), click Insert>Module, and paste the following code into your module:
Function Cost(orders As Double)
If orders < 500 Then
Cost = 20
ElseIf orders >= 500 And orders < 1000 Then
Cost = 18
ElseIf orders >= 1000 And orders < 1500 Then
Cost = 16
ElseIf orders >= 1500 And orders < 2000 Then
Cost = 14
ElseIf orders >= 2000 And orders < 4000 Then
Cost = 13
ElseIf orders >= 4000 And orders < 6000 Then
Cost = 12
ElseIf orders >= 6000 And orders < 7000 Then
Cost = 12
End If
End Function
Now you can just do =Cost(CELL) to calculate.
