I have a router in my COmpter room (wireless) WRT54G. It is hardwared to my PC and MY cable modem. I have 1 other PC on a Wireless Card and it is on the Internet with no issues.
I have a second Router WRK54G.
I have 3 devices that do not allow wireless access all next to each other in another room.
i should be able to plug all 3 into the second router WRK54G (hardwired) and that router can be i guess a Gateway? It should be able to talk to my other wireless router so that the 3 devices connected to it can have internet access and be in the network. Correct?
I have looked on Linksys site and what not -
How do I get this to work?
DO I have to plug the second router into my PC (or other router) first and configure it? Obviosly they are both 192.168.1.1. I already changed my main router to 192.168.1.2 - so the second router is 192.168.1.1 (default). I Can't log into it... From my Wired PC or my Wireless PC. Both PC's only see the router and the Cable modem of the first (wrt54g).
Can someone help me out getting this to work.
I honesty dont want to buy a $99 G adapter for my Xbox 360 and the 2 other devices only accept WIRED either net connections.. BUt if I wire them to a ROuter (Wireless) that can Wireless COmmunicate with the first router and be on the same network..the other 2 devices would act as if they were Hardwired directly tot he first router in theory.
Any help would be mucho appreciated!
Thanks in advance..
Thanks in advance..
