My case fans came with 4-pin molex connectors attached to them, which is great...until you want to use a fan controller. I ordered the Zalman one. Anyways, I need to convert my connections to 3-pin ones.
So I bought the female 3-pin fan connectors and then noticed that there's no metal in them, just plastic. Also, I don't know how to secure the wires in this connector. Looking at the 3-pin connector for the fan on the Intel stock heatsink fan in the closet, it looks like there's a metal along the top of the connector, above where the wires go in. And then the male end plugs in below that.
I've googled, searched this forum and others, and I can't find out how I'm supposed to do this wiring. Also, is there any tool needed to help secure the wire in the connector? Any cheap alternative to an actual tool?
Thanks
Thanks
