Help wioth suggestions on HTPC build
DGMurdockIII
looking for some suggestions on what to get for a 4k HTPC build. that I use to play dvd and blu-ray movies and online streaming , and downloaded movies on
would like a card that has HDMI 2.0 if possible hdmi 2.0a and wireless built in to motherboard and DDR4 if you can get it with wireless and if at all possable no killer nic also i do do 5.1 audio so i need to be able to do that be it through HDMI or toslink/optical
motherboard has to be micro atx see case im using below
the case im using is http://www.in-win.com.tw/Corporate/en/goods.php?act=view&id=BK623
also im going to be buying this reciver http://amzn.com/B00IQ0SE22 if that make any difference to upgrade my old one
D
Deleted member 88227
Guest
Budget?
Where do you live?
What exact parts do you need?
DGMurdockIII
under 500 if possable
i like in usa indianapolis in
i only need motherboard , cpu and videocard bluj ray drive i have coverd and hard drive as well and memory as well i have coverd i just need help with those three
EndersShadow
I just built a HTPC (installing updates as we speak) using a ASROCK 1150 socket motherboard .... It's their H97 Anniversary one + 3220 CPU and NO GPU.... But with a budget of 500 the sky's the limit for you my man....
I'm in Brownsburg IN myself. Id hit up Frys. I was in there myself today and looks like they are redoing their stuff so they will have some deals on display units or stock they are phasing out....
skiddy
For HDMI 2.0 with a discrete card you will need a GTX 950, 960 or 980Ti. I believe those are the only options at the moment.
I believe some skylake boards do support HDMI 2.0, but a good portion of them are still only 1.4.
Are you sure you want wireless? In some people's houses WiFi reception is not good. And you'll be using UHD video files over it probably.
