Bisectors Fore
- Aug 24, 2008
I have Windows XP Pro 32-bit with SP2 installed on my computer, and I just started having this weird problem with it today. I turned the machine on, it booted up and I put in my password. Then it paused for an abnormally long time saying it was loading my setttings, and when it finally got into my desktop, the taskbar and all icons were gone. The only way I can run programs is through the Windows task manager, and anything that uses Windows explorer will not work. I was using the computer earlier today and was not having this issue. I have checked for viruses and spyware and that has not fixed the problem. I have searched online and found others having the same problem, but I have not found a solution that worked. If anyone knows how to fix this without re-installing Windows, (I just did that a week ago) I would greatly appreciate help. Thanks.
