Airbrushkid
- Aug 27, 2007
Here's how it started.
Sorry this was on another thread from a different forum. So is there a way to fix this without formatting and reinstalling?
Let me start off with I have Windows XP Pro and Vista 64 installed as a dual boot on the same drive. So I tried to install Windows 7 RTM on the same drive.
Ran into a problem. Could not install on same drive. So I installed on different drive, look good until I rebooted. It seems there's no way to boot to Windows 7. I see XP and Vista in boot up. But no 7.. It's on that drive but don't know how boot from it. Except it will boot if I have the install disc in the dvd drive. Does anybody know how what why?
So I am assuming that if I use WD Data Lifeguard Tools to format the drive Windows 7 is on and use the option to make the drive so I can boot from it. Then reinstall Windows 7. This will solve the problem?
Messed up won't boot into XP and no option to boot into Vista now. Help
Edit/Delete Message
I am having a bad problem now. I cannot boot XP. How do I fix it? I tried to use repair with the disc and used the fixboot option that didn't fix it.
Edit/Delete Message
Let's see. I need to get Windows XP Pro to boot up, I'll worry about Vista and as for Windows 7 it's gone for now. I tried the repair option and used Fixboot. That is why Vista won't boot. I tried and use Bootcfg, it won't let me Add or Rebuild. It's say use CHKDSK I did but I get this message - The volume appear to contain one or more unrecoverable problems, and this is why Bootcfg won't allow me to Add or Rebuild. When I try to boot XP it makes it to the blue splash screen just right before you login and just hangs there. Can someone help please?
Update I got Vista to boot with disc. And then remove XP using Vista disc manager. Now I am trying to figure out hoiw to get Vista to boot without disc in drive. Anyone?
Edit/Delete Message
