i3lueHorneT
- Sep 16, 2005
Alright, I recently had a HDD failure, but I'm on a RAID 0 and am therefore not sure which disk is producing the errors (is there a way to know while still on the RAID 0 config?). I'm now trying to reconfigure the setup for a single disk, thereby needing to bypass the RAID card (right, I can't just unplug the one of the HDDs can I?), what I'm trying to do/need to know is:
1. Are there any jumper caps I need to change going from a Hight Point RAID card to the mobo's IDE slot?
2. The same IDE cables that the RAID card uses can be used for the mobo IDE slot right?
3. How should the jumper look/be set to on the HDD?
4. I have two CD/DVD drives running off a single cable in 'SEC_IDE1' slot, that doesn't really apply to anything here right, I use the 'PRI_IDE1' slot for a cable that breaks into two connectors?
5. What do I need to do in BIOS once the HDD is installed?
6. Anything else I need to do/set before booting? Is there any kind of 'boot safety' lets say if I hook one of these components up wrong will there be an error before something can be damaged/can I fry something, no so long as I have the power cabling correct right?
7. Once the single drive is installed, I'll obviously need to format/reinstall the OS, will I be able to run any HDD diagnostics prior to this however?
8. Is it at all possible that, through the RAID, both HDDs were brought to physical failure or is this issue limited to failure by one of the disks -that is can a RAID card create physical failure on a HDD?
NOTE: HDD Failure - At this point I can't even get past WinXP login, safe mode doesn't help, an I/O error comes up and it freezes, AUTOCHK tries to run each boot but it eventually crashes (I 'press any key' exit), and when I was last able to get to my desktop I would get all kinds of 'STOP: Hard errors' 'Hard error' popups, and similar all forcing a crash or hardboot, so I'm pretty confident its a hard disk error.
SPECS:
3yr 3mo+ rig by: abspc.com
ASUS A7N8X Deluxe MOBO
2x Western Digital 80GB 7200RPM 8MBCache EIDE WD800JB
High Point RocketRAID133
CDRW
DVD
Lastly, anyone looking to buy a WD 80GB disk?
/Thanks.
peace,
SPECS:
CDRW
DVD
/Thanks.
peace,
