thx, but Ive owned crucial ballistiks in the past (not the ddr2 ones) but mine always seemed to fail after 6 months for some reason. crucial rma dept is awesome, but id rather go through that again
Also, you should put a fan on top becasue they tend to run hot. Bought a bunch and only had 1 bad stick. Newegg refunded me. Could've been 1 of the 2 scenarios.
