Help selecting a 24 inch monitor
Ghoststalker
I'm looking to upgrade my monitor, hopefully to a 24 inch (23.6 is acceptable).
Preferences:
Used primarily for gaming and web browsing
1920x1080p preferred
Easy to calibrate
120 hz preferred
Budget:
$400
Its not 120 Hz but the HP 2509b us a superb monitor and is $250 at Best Buy and if you're lucky they sometimes have it on sale for $200! I picked mine up for 2 bills and its easily the best monitor I've ever owned. Im primarily gaming on my rig and it works great and I have noticed zero lag or ghosting. I argue its the best monitor on the market dollar for dollar.
ANy suggestions for a 120hz monitor? I see the new samsungs w/ 3d support, but $600 is kind of asking a bit much :)
Yup, based on your preferences, the Benq XL2410T is the only option as far as I know.
If you're willing to go down to 23", the ASUS VG236HE probably has a better image.
That's based on the reviews I have read. I don't have any first-hand experience with any of those.
I can vouch for the Samsung S27A950D though. I've had it for a few days now, and while it's far from perfect (TN panel etc...), gaming@120Hz is pure bliss.
