scharfshutze009
- May 22, 2010
I accidentally copied another access points IOS to this AP a few months ago, but forgot that the radios were just disable and it went heywire. This happened because I forgot to disable my TFTP server or clear the TFTP-Root folder and now I'm in this mess. I finally got Cisco to help me with this device and they let me download an official IOS from their support tab after logging in with my Cisco ID, but after asking for help on there support forum nobody has responded yet. Can anyone help me on here. I've tried the following connected to a router and with crossover, but for some reason the tftp server cannot ping the AP and when trying to copy the file to the AP the connection times out because a connection can't be established:
31996928 bytes available (1024 bytes used)
ap: tar -xtract tftp://192.168.1.2/ap3g2-k9w8-tar.153-3.JE.tar flash:
ap: set DEFAULT_ROUTER 192.168.1.2
ap: set IP_ADDR 192.168.1.3
ap: set NETMASK 255.255.255.0
ap: tftp_init
ap: ether_init
Initializing ethernet port 0...
Ethernet speed is 1000 Mb - FULL Duplex
ap: tftp_init
DPAA Set for Independent Mode
DPAA_INIT = 0x0
tftp://192.168.1.2/ap3g2-k9w8-tar.153-3.JE.tar: connection timed out
ap: set DEFAULT_ROUTER 10.18.90.1
ap: set IP_ADDR 10.18.90.102
ap: tftp_init
ap: ether_init
ap: tftp_init
Unknown cmd: tftp_init
ap: tar -xtract tftp://192.168.1.2/ndependent Mode
tftp://192.168.1.2/ndependent: connection timed out
ap: DPAA_INIT = 0x0
Unknown cmd: DPAA_INIT
ap: tar -xtract tftp://10.18.90.101/ap3g2-k9w8-tar.153-3.JE.tar flash:
tftp://10.18.90.101/ap3g2-k9w8-tar.153-3.JE.tar: connection timed out
ap:
ap: tftp://192.168.1.2/ap3g2-k9w8-tar.153-3.JE.tar: connection timed out
Unknown cmd: tftp://192.168.1.2/ap3g2-k9w8-tar.153-3.JE.tar:
ap: ap: set DEFAULT_set NETMASK 255.255.255.0
Unknown cmd: ap:
ap: ap: tftp_init
Unknown cmd: ap:
ap: apng ethernet pois 1000 Mb - FULL Duplex
Unknown cmd: apng
ap: ap: tftp_init
Unknown cmd: ap:
ap: Un tar -xtract tndent Mode
Unknown cmd: Un
ap: tftp://192.168.1ion timed out
Unknown cmd: tftp://192.168.1ion
ap: ap: DPAA_INIT = act tftp://10.18.90.101/ap3g2-k9w8-tar.153-3.JE.tar flash:
Unknown cmd: ap:
ap: tftp://10.18.90.3.JE.tar: connection timed out
Unknown cmd: tftp://10.18.90.3.JE.tar:
ap:
Can anyone on HF help. Don't ask me why the output looks as follows here:
ap: tftp_init
ap: ether_init
ap: tftp_init
ap: DPAA_INIT = 0x0
ap:
Unknown cmd: ap:
ap: ap: tftp_init
Unknown cmd: ap:
Unknown cmd: apng
ap: ap: tftp_init
Unknown cmd: ap:
Unknown cmd: Un
Unknown cmd: ap:
ap:
ap: tftp_init
ap: ether_init
ap: tftp_init
DPAA_INIT = 0x0
ap: tftp_init
ap: ether_init
ap: tftp_init
ap: DPAA_INIT = 0x0
ap:
Unknown cmd: ap:
ap: ap: tftp_init
Unknown cmd: ap:
Unknown cmd: apng
ap: ap: tftp_init
Unknown cmd: ap:
Unknown cmd: Un
Unknown cmd: ap:
ap:
ap: tftp_init
ap: ether_init
ap: tftp_init
ap: DPAA_INIT = 0x0
ap:
Unknown cmd: ap:
ap: ap: tftp_init
Unknown cmd: ap:
Unknown cmd: apng
ap: ap: tftp_init
Unknown cmd: ap:
Unknown cmd: Un
Unknown cmd: ap:
ap:
