Hello,
My Corsair PSU recently died and it is sent off for RMA. In the mean time I have connected up a spare PSU.
I stripped the PC down to RAM, GPU and CPU. Out of the case, onto cardboard to avoid shorts.
With the old dead PSU, on powering up the PC, no video output, no post beeps, CPU/GPU fans did NOT spin up.
With the working PSU - CPU & GPU fans spin up for a few seconds then die, spin up again, and die, etc etc. Cant turn it off from the front (need to switch off from PSU). No beeps, no monitor signal.
Took out the CPU - now if I connect the CPU fan, it spins up and keeps spinning. The LED on the front of the PC comes on and stays on. I can turn the PC off from the front switch. Still no post beeps though.
From this - is it certain the motherboard is dead? Or is it possible the CPU is also / instead of dead? I dont have another system to test them on.... so I am going to have to buy either a new mobo or a new CPU but I am trying to work out which I need....
Thanks
Thanks
