Hi, I just got a new Samsung 39" LED TV and having a problem with recommended resolution of 1080p. Model is: UN39EH5003
The problem is that when I set the resolution of 1920x1080 in computer, the pictures becomes inch or two bigger so it does not fit the screen. Its like you can't see the clock and start menu of the computer. Also, the pictures becomes too bright and not clear.
All other resolutions work right and look beautiful. I'm using it at 1680x1050 at the moment.
I have it connected to HDMI from a computer with ATI 6870. Same problem wile connected to a Laptop's HDMI port. Changed the HDMI cable and still have the same problem. I'm using 6feet cable.
This is my first flat screen TV so I don't know if its normal. I wish it was a 4k monitor
