ucisilentbob
- Oct 11, 2004
Stupid stupid Maxtor.
So i have two hard drives in my computer. my main hard drive is a WDC 120JB, and my second hard drive is a Maxtor DM9 250G. i decide that i need to upgrade my main hard drive so i get myself a Maxtor DM10 250G to replace it. So i finally get the drive so then i detatch my DM9 and place the DM10 in the slave on my primary ide channel. i load up into windows, use partition magic 8 to set up the drive and then i create two partitions on my new drive. one 40g partition for my OS and the rest for archiving. I transfer all my files on the WDC120JB onto the second partition on the DM10 then shut down the computer.
I attatch my drives DM10 as my primary master, and my DM9 as my Primary Slave. Now when i try to install windows i see that when i'm prompted to choose the partition that i want to install windows on it shows both hard drives as unpartitioned.
I load up partition magic in dos and see if i can re-detect my partitions and now i get nothing. when looking at my DM10 when its in the Primary master, it just says "error #01" and my DM9 just shows nothing.
So i think great, this is gonna be fun. So then i grab my WDC 120JB and put it back under Primary Master (that's how i'm typing this right now) and now i cant even see my DM9 anymore.
So i figure that i'd get back into partition magic in windows and now it just gives me an error.
"Error #90
EZ-Drive has been detected on drive 1, but EZ-Drive is corrupt. Run the EZ-Drive setup diskette to correct this problem. For EZ-Drive support contact your EZ-Drive provider."
Any suggestions to save my DM9? or actually get windows to install?
All the help you guys have would be great!
"Error #90
