MrGuvernment
- Aug 3, 2004
i am going to be doing the outside and inside of my case, for the inside, since it is already the bare metal surface, i assume i just need to sand the parts enough to add primer and paint? or do i need to do the same work as the outside?
i plan to do an external white mirror / or very glossy finish.. inside will be white as well, likely....
