Help... Nvidia driver stuck in limited RGB
Discussion in 'nVidia Flavor' started by LigTasm, Mar 25, 2018.
  1. LigTasm
    LigTasm [H]ardness Supreme
    4,909
    Jul 29, 2011
    Fresh install of Windows 10 on a new machine with a 1060, installed the latest 391.24 drivers and then the colors went dull. Originally I was able to change it from limited to full (this is over DP, fucking thanks Nvidia) and it worked for a split second and then reverted back to limited so it basically looks like grayscale.
    I used DDU and rolled back to the previous driver and it did the same thing. What the hell? Anyone know how to fix this? Using the Windows default mode doesn't fix it either.
  2. ManofGod
    ManofGod [H]ardForum Junkie
    9,983
    Oct 4, 2007
    Make sure that HDR and WCG is off in the Windows display settings.
    AceGoober and Armenius like this.
  3. ob1
    ob1 2[H]4U
    2,274
    Apr 17, 2000
    Did you change back to full from limited in the control panel? I have to do this on several monitors with my 970. Each driver install changes it back to limited.
  4. LigTasm
    4,909
    Jul 29, 2011
    Thats literally what I'm talking about, it doesn't matter what mode its in it doesn't change to full. It shouldn't even be trying to use limited mode on a DP connection anyways, but it is.
  5. eclypse
    eclypse 2[H]4U
    2,992
    Dec 7, 2003
    Make sure your selecting the right resolution under the right heading.. like monitor. I noticed last time there's different headings now like tv/display ext.
  6. LigTasm
    4,909
    Jul 29, 2011
    Yeah it is set to monitor, correct resolution and refresh. Everything is normal. I have to switch it to Nvidia settings because PUBG still trips out with green bars on the screen if you use the default windows setting, usually its no issue but this time it just seemed to get stuck.
  7. LigTasm
    4,909
    Jul 29, 2011
    Ok I fixed it, it was Gigabytes APP CENTER causing the screw up. I removed it and set the colors to full again and it worked.
  8. melk
    melk Gawd
    912
    Jan 21, 2014
    Glad you figured it out. That's the number 1 reason why I steer clear of bundled crapware like that.
  9. polonyc2
    polonyc2 [H]ardForum Junkie
    16,097
    Oct 25, 2004
    what's the difference between 'default color settings' and 'Nvidia color settings'?...I've always left it at default...is Nvidia color better?
  10. Decibel
    Decibel 2[H]4U
    3,808
    Nov 10, 2000
    NVIDIA color settings gives you more controls, whereas default is just that, whatever it autodetects to.
  11. LigTasm
    4,909
    Jul 29, 2011
    The issue for me was that PUBG will show green lines on default windows values on some cards, but if you change it to Nvidia the Microsoft settings are overridden and it works fine.
    To elaborate, Gigabyte APP center isn't just for their apps apparently, it also can interface with the control panel and several other things like power settings. It also runs continuously in a separate desktop (if you use the tile view you'll see it) and it fucks up the whole system.
    AceGoober and cageymaru like this.
  12. Mazzspeed
    Mazzspeed [H]ard|Gawd
    1,423
    Dec 27, 2017
    It's actually very interesting that the drivers default to RGB limited when standard PC application requires the use of RGB full? Good job NV.
    Checked all my machines, it's only the Windows drivers that do this, the Linux drivers default to RGB full.
  13. LigTasm
    4,909
    Jul 29, 2011
    Normally it only does it in HDMI mode. Is been like that for a while now and they have yet to fix it.
  14. Mazzspeed
    1,423
    Dec 27, 2017
    The monitor on my Windows PC is connected via DP, and it's defaulted to RGB limited. I had to manually select RGB full.
  15. XoR_
    XoR_ Gawd
    654
    Jan 18, 2016
    What monitor is that?
    I see 240Hz... if that ist G-Sync monitor then this would be considered as epic fail...
    Armenius likes this.
  16. Armenius
    Armenius I Drive Myself to the [H]ospital
    16,516
    Jan 28, 2014
    It was added as a compromise to Microsoft trying to add implicit support for HDR color. There was a conflict between what NVIDIA was doing for HDR color and what Microsoft did. NVIDIA color always seemed to give better color reproduction than Microsoft to me, even at default settings.
    I've been through 3 monitors: one with HDMI, one with DL-DVI and my current with DisplayPort. All three have always defaulted to RGB full whether it was Windows 7, 8.1, or 10. Only when I have connected a TV has it defaulted to RGB limited. With my new Samsung TV it automatically detect the black level I have selected on the TV and change between full and limited based on that.
  17. cageymaru
    cageymaru [H]ard|News
    19,233
    Apr 10, 2003
    The Gigabyte app center is the most vile software on the internet. Not only does it crash your PC and make weird choices without you asking it to do a darn thing; it will use up 25% of the system resources while hosing your system. The motherboards are rock solid. The app center crap need to DIAF.
  18. polonyc2
    16,097
    Oct 25, 2004
    does 'Nvidia Color Settings' ever cause any issues in games or desktop applications?...or does it only matter if you have an HDR enabled display?
  19. Domingo
    Domingo Skip My Posts
    16,759
    Jul 30, 2004
    MS's version of HDR basically broke Nvidia's version. Before the first Creators update, HDR content would auto-enable itself no matter what your display settings were. I left my setup as Full-RGB all of the time because that's what most of my other devices (Xbox, PS4, etc.) use. The system simply knew when HDR was being used and swapped over automatically.
    Thanks to MS's update, you have to have everything set to "default color settings" or HDR simply won't work with no explanation given. For some apps that don't use true fullscreen (Netflix & PowerDVD), you also have to enable it on the desktop.
