Help: non SSL device to google drive
ptrout
I have a semi-dumb datalogger. I can script it to generate a "POST" data to google drive.
I can do this from a webbrowser on PC, but from the device it failed due to lack of SSL certificate.
Is there way using small netbook or pc, where I can send data to PC via HTTP, then have it relayed via HTTPS to google drive ?
Thanks
2bluesc
I understand you want to get it to Google Drive, but would consider logging it somewhere else and then periodically copying it to Google Drive?
if so checkout this: https://data.sparkfun.com
It's an IoT type play where dumb/simple embedded devices (i.e. microcontrollers) and dump data to the web.
