So on Friday i had a break in at my place and my 4k tv was stolen. Fortunately the tv I had originally wasn't very expensive a Seiki 42 inch model (SE42UGT I believe.)
Anyways my landlord is going to replace my tv and i'm trying to figure out what to get. I'm trying to find something that would work well as a computer monitor mainly for gaming. I will be using a 1080 gtx to power it. I've spent several hours trying to look through reviews and everything and keep finding differing opinions and such. I'm hoping i can find some fellow [H] peeps that have actually used 4k TVs in the same way I plan to.
These are the things i'm looking for:
- 4k@60hz, 1080@120hz, @ low input lag. Basically something I'd be able to play FPSs, Rocket league and such and not notice input lag. Games that i can't run at acceptable frame rates at 4k i'll either run at 1440 or 1080.
- Chroma 4:4:4
- Minimum of 40 inches, Max of 50 inches
- HDR at 10 bit but this is less of a requirement
- Low price as I bought the Seiki for only $250 a while ago and i don't expect my landlord to chip in more than that. I'll cover what cost goes above that. I plan on selling my current monitor and just using the new TV for everything.
- Chroma 4:4:4
