MemoryInAGarden
- Oct 26, 2003
The system in my signature is becoming a bit long in the tooth and I've decided to finally migrate from XP to Vista 64-bit for good. I don't really want to scrap the entire machine now since I don't game on it all that much; I just want to give it a little extra pep getting around Windows.
1) The RAM I'm using is some old Corsair Value PC3200 I picked up years ago that isn't only running at 333 mhz. The system will not overclock at all, not even 50 mhz or so. Right now, with one IE window and Windows Media Player up, I have a whopping 24MB out of the 2GB free. I need more RAM. Should I try to find a 2x2GB kit or get 4x1GB modules?
2) Is a 4800+ adequate for doing simple gaming like WoW in Vista? Processor usage on each core is around 65% with just the couple things above running. It seems like I don't have nearly enough CPU power to do even the simplest things besides browsing my desktop.
3) I'd like a small graphics upgrade. Would I be better off looking for a 7xxx series AGP card or getting a PCIe board and something like an 8600?
