Help me plz with extracting something
Discussion in 'Operating Systems' started by kingofwar, Dec 1, 2010.
  1. kingofwar
    kingofwar n00b
    1
    Dec 1, 2010
    i have winrar and 7 zip but when i try to open my zip
    i have downloaded a rs pserver i need the cache and stuff for the download cleint when i extract only the bat comes out the src and cache are invisable and dont show but are there confusing
  2. Tawnos
    Tawnos 2[H]4U
    3,807
    Sep 9, 2001
    Please post again in English, rather than gibberish.
  3. Bahamut
    Bahamut n00b
    0
    Apr 27, 2010
    If you have a Zip archive and you extract the contents and you can't see the files, it's possible that some of the content had the Hidden attribute set and so they're not going to show up in a cursory view.
    You may need to change your Explorer options so you can see hidden files, folders, and drives before you'll see those contents - that is, if they're actually using the Hidden attribute.
