Has anyone been able to OC the P4 540 LGA 775 3.2GHz over 3.927GHz and keep it stable with an ASUS P5AD2 Premium? I tried, but taking the CPU any higher results in instability problems. When the CPU goes under load the PC crashes into a blue screen that says something about hardware problems blah blah. Heat is not the problem as you can see:
My BIOS Settings are:
FSB = 245
VCore = 1.45v
MemCore = 1.9v
PCI Clock = 33.33MHz
AI Booster = Disabled
Memory Timings: 5-4-4-12
FSB = 245
VCore = 1.45v
MemCore = 1.9v
