Help me make Sort By Date Modified the same on Vista as it is on XP please
Discussion in 'Operating Systems' started by shaolin95, Sep 19, 2009.
  1. shaolin95
    shaolin95 2[H]4U
    2,785
    Jan 5, 2006
    Hi!
    This has been annoying me a lot.
    Let's say I have a folder with many files to which I download to.
    On XP if I download a new file to it in order to find it the easiest for me is to SORT BY Date Modified and then it will show at the very last file on the list...easy enough.
    In comes Vista 64 and that does not work at all...it still shows up somewhere else.
    Any ideas?
    Thanks
  2. dugn
    dugn Limp Gawd
    395
    Aug 16, 2009
    The same feature exists in Vista and Win7. Just be sure to right-click on the headers at the top of ecah olumn to pick the headings you want (be sure to add Modified Date), drag the new header(s) you added to the right position you'd like them -then click on any of them to sort by that column header.
