HELP ME FIND: Whiteboard/Interactive Display with ability to save
Discussion in 'Displays' started by jaypeezee, May 10, 2019.
  1. jaypeezee
    jaypeezee Gawd
    989
    Jun 11, 2003
    So I was tasked with finding "THE PERFECT SOLUTION" for our needs at work, and I AM NOT the IT guy :facepalm:
    We will be replacing a traditional whiteboard that we use frequently. We would like to replace the current white board to a digital display (used in the generic sense) to display videos, power points, docs, etc, WHILE retaining whiteboard capabilities... Touch input is NOT a must - although I understand most will probably come with. We will have a wireless keyboard and mouse on the table to facilitate.
    Ideally, we would like our whiteboard notes/drawings saved to a digital format (pdf/jpeg) to be sent out to those who need the info... MAJOR plus if we could use traditional dry-erase markers instead of a specific stylus, however that is not a deal breaker.
    Our current solution is ta quick cell phone photograph of the board and emailed/MMS.
    Suggestions? ideas?
  2. Riouken
    Riouken Limp Gawd
    209
    Aug 28, 2015
  3. jaypeezee
    jaypeezee Gawd
    989
    Jun 11, 2003
    Hmm, definitely pricey and smaller than we were expecting...
    Something +/- $3Kish
  4. Brian_B
    Brian_B 2[H]4U
    2,564
    Mar 23, 2012
    Watching this because we do the exact same thing
  5. Tomcat84
    Tomcat84 n00b
    2
    May 11, 2019
    We acquired some iiyama 86 and 65 inch 4K touchscreens with ability to draw on etc last year at work and were quite pleased for our purposes (slightly different than yours though, mainly for viewing digital material). Think they might cover most of your requirements (except using regular dry erase markers, don't think that's an option). Quite sure you can take screenshots of the originally displayed content plus whatever you drew on top. I do think that in order to draw on something it would take a screenshot of what was going on at that time (i.e. I think you cannot draw live over video while the video kept playing, it would freeze the frame? Might be wrong, it's been a while since I used the screens as I've since transferred elsewhere) That was in Europe though, not sure if they are available anywhere in the States. Maybe this helps?
    https://iiyama.com/us_en/products/prolite-te8668mis-b1ag/
  6. jaypeezee
    jaypeezee Gawd
    989
    Jun 11, 2003
    Thanks for that! I've been researching and came across SmartKapp by Smart Board. A traditional white board with exactly what we're looking for, sans display.
    It seems theres a projector option with white board, need to research a little more
  7. pendragon1
    pendragon1 [H]ardForum Junkie
    12,415
    Oct 7, 2000
    we have a casio at work, one of the education units, it projects onto a white board, it has an optional "touch" unit and an app that can do what you want, I think.
  8. purple_monster
    purple_monster Limp Gawd
    370
    Jun 1, 2018
    this literally does not exist for under 10k at least and completely custom if your communal whiteboard is even close to normal meeting room whiteboard size(5ft+ ???). We have several 4ft displays for interactive maps around our headquarters and they are NOT cheap or off the shelf.
    this sounds like a joke, or you are being baited into an expensive failure. either that or your company is run by complete morons who have seen minority report too many times and think all tech is magic. you are fucking with us.
    edit: there is some interactive projection and you could ask for a demo. i dont know where how great it is now, we were early adopters and it kind of fizzled out as it was more trouble than it was worth. think about this exchange, constantly:
    (presenter touches button while screen sharing with finger)
    >bubble-type animation goes off, nothing happens
    (everyone in room)
    "you gotta, no- lightly do it"
    (presenter tries again)
    "how- did i do it? its it going?"
    >more bubbles pop at his finger, nothing happens
    (everyone in room)
    "no lighter, right.. yep like that)
    >screen finally changes
    (presenter)
    "i thought i did that the first time!"
    IT shenanigans ensue. But im guessing its a ton better now. ask for a demo and have your team try it out.
  9. jaypeezee
    jaypeezee Gawd
    989
    Jun 11, 2003
    Wait, how do you know where I work o_O
    Unfortunately, my admin does not trust in our IT department and routinely looks to me for input... Even though my title is as far away from IT work you can imagine!
    purple_monster likes this.
  10. sethk
    sethk [H]ard|Gawd
    1,590
    May 3, 2005
    I have seen digital whiteboards discontinued at several corporations now, that had them for years.
    A much easier solution is use an app on mobile (e.g. Microsoft OneNote on iOS or Android) to take a picture of the Whiteboard and it will deskew (i.e. straighten) white balance adjust and clip just the whiteboard part of the image and paste it into a shared notebook for the group (or personal notebook if you prefer). It also OCRs the text. Plus the whole thing is organized and searchable. You can email the picture out from the app if you want.
    Overall this works much better and more consistently than digital whiteboards in the long run, which are an IT nightmare with custom crappy software for the most part. The segment is dying off fast, minus new solutions like the Surface Hub which are quite expensive.
