Help me find Lian Li square motherboard standoffs
Jsalpha2
Mine are old and bent and wobbly, plus I'm missing a couple. Thanks
Starfalcon
Thats going to be a hard find, most of the old skool Lian-Li PC-60 and 70 cases came with those. Finding them 20 years later isnt going to be easy, I bougt several of those cases and I dont have more than 1 or 2 extra left at this point now either.
Dan_D
Extremely [H]
I hated building in those cases. If you torqued the motherboard screw down even a little bit hard they'd twist those things. Good luck.
Jsalpha2
I can rig something, yes, but I was hoping t get a dozen new ones. I still love the case. As long as I don't go back to an ATX mobo I'll be ok. Thanks
