Zoson
- Aug 4, 2001
I'm building an HTPC and I need a case, and heatsink.
Case:
1. The case needs to be no greater than 17 inches wide, 7.5 inches tall, and 15 inches deep.
2. It must have at least 1 external 5.25" bay for a blu-ray drive.
3. It must have at least 4 internal 3.5" bays for hdd's.
4. Optimally, it would look like a receiver or component of some kind. Simple is good. LED's are bad.
5. Aluminum is a plus(for weight savings).
6. Must support mATX motherboards(I've got an ASUS R4G for the build).
Heatsink:
1. Must be no taller than 170mm(which is ~7 inches, basically it has to fit in the above described case)
2. Must clear Mushkin Ridgeback memory
3. Compatibility with Gentle Typhoons is a plus.
4. Will be cooling a 3930k(130W TDP) overclocked mildly.
So far I've been completely unable to find a case that actually fits all my criteria... Figured I'd post here, maybe someone's seen something I haven't!
For the heatsink... It seems like a cogage true spirit 120 would be a good call if I have all 170mm to work with height wise for the cooler... Otherwise I was looking at the CM GeminII S524.
Any suggestions welcome!
Case:
Heatsink:
