Help me build a HTPC for a friend
Silentbob343
His old HTPC gave up the ghost and he asked me how to proceed with a new build.
Requirements; inexpensive, wants to be able to bit-stream audio to his receiver, and strictly for media playback-no DVR capability.
I was thinking Intel i3;
He can get an i3 for $100 and an H55 based motherboard for $80-$100. It'll have plenty of power to decode HD streams, is fairly inexpensive, and it can bitstream HD audio.
I know you can bitstream with AMD setups as well with a discrete GPU, but i have no idea what processor, chipset, and GPU to recommend. What would a comparable AMD based system cost?
CrimandEvil
Dick with a heart of gold
"Baseline:"
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131408
http://www.newegg.com/Product/Product.aspx?Item=N82E16813500037
http://www.newegg.com/Product/Product.aspx?Item=N82E16813500036
AMD:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103826
http://www.newegg.com/Product/Product.aspx?Item=N82E16813500015
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131318
http://www.newegg.com/Product/Product.aspx?Item=N82E16813500021
Intel s775:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116265
http://www.newegg.com/Product/Product.aspx?Item=N82E16813141015
http://www.newegg.com/Product/Product.aspx?Item=N82E16813121355
http://www.newegg.com/Product/Product.aspx?Item=N82E16813121353
http://www.newegg.com/Product/Product.aspx?Item=N82E16813500035
Intel s1156:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115222
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157182
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128420
The baseline systems are what it will take to build a cheap HTPC that can handle HD content easily, the problem with it is that the Atom CPU used is a bit too slow if you have a large media library; it'll choke on the HTPC's GUI. If you go the Linux route and use something like XMBC then the Atom does better, chokes less.
Stepping up to the AMD setup you've got a formidable system capable of HD video playback and it supports 7.1 LPCM HD audio over HDMI. It'll handle anything you throw at it.
Either of the Intel setups support the same features as the AMD systems with the addition of supporting TrueHD and DTS-MA audio over HDMI on the s1156 based systems but it is more expensive for a feature you might not even be able to use if you don't have the proper audio setup. The G45 and the 9000 series systems are pretty much identical to the AMD system.
