tankman1989
- Aug 21, 2009
I have the opportunity to buy some hardware but I'm having a tough time finding out what the specs are of the equipment. I'm not real familiar with blade equipment so I might end up passing on this hardware, I'm looking at this hardware for office use but since there is so much I will probably resell some of it unless I get a major influx of business.
Can blade servers be used outside the "cage"? I don't see a PSU on these things so I'm wondering is a PSU can be rigged to attach to it by making an adapter with 12v & 5V rails. Basically getting either a regulated Bench PSU or modified computer PSU to a custom build connector to run the units.
The stats list that each of these have 2 Opteron 2.4 Ghz CPU's and 8000 series MOBO chipset, so it seems like these are pretty new CPU's? Can anyone help identify possible CPU's from this info?
Also, it says that the RAM available is 4x4GB 333MHz, 400Mhz speed, what does that mean? Which speed is that, I've seen other servers list that as well- My IBM has the same PC2-3200 4GB sticks that say 333Mhz on them but all info pn the net say 400Mhz. Any ideas?
This stuff is at an auction house and the only info available is the following:
3 Gigabit LAN adapters
2 AMD Opteron 2.4 GHz Number of Installed Processors 2
16gb installed - 4x4 GB DDR SDRAM - RAM Speed 333 MHz, 400 MHz Number of Memory Slots 8 x DIMMs
Motherboard Chipset AMD Opteron 8000
Storage Maximum Storage Capacity 120 GB (none included)
Integrated Lights-Out (iLO)
Dimensions (per unit) Height 1.61 in. Depth 25.35 in. Width 4.72 in. Weight 8.19 lb.
