Sandbox Magician
- Mar 4, 2005
My current system:
1.1GHz Athlon
256 MB PC133 SDRAM
Gigabyte AMD 760 Motherboard
30GB Maxtor HDD
Elsa Gladiac 920 GeForce 3 Video Card
Plextor 16x DVD-RW+/- Burner
I bought this computer from this local hole-in-the-wall quite a few years back when I didn't know the slightest about computers (I bought it with a CD-RW and just recently upgraded with the DVD drive). Shortly after I bought this system and paid for a 1 year warranty they went belly-up, but anyway I got ripped off. I gave them somewhere around $1200 and this is what they gave me. I had nothing but problems from the start, and somehow managed to use this system for the past few years messing around with it. As soon as I build my next system I'm gonna take this POS computer in my backyard and do it Office Space style and smash it to smitherines.
Well to make a long story short, after dealing with this system for so long I taught myself a little bit about computers, and I think I'm capable of building my own. However, I only have a small budget of around $800-$1,000... and I don't want to keep any parts from my current system with the exception of my DVD burner, not even the case. I want a good case with nice cooling because my current computer has the case cover off with a house fan blowing into it. I've had bad problems with overheating.
I need help from all of you pros to tell me what specs to put into my new system. Right now I only use my computer for DVD authoring and different types of input to output encoding, but I want to get back into gaming.
Right now it takes me about 18 hours to encode a DVD, so I hope to cut that down quite a bit with my new system. I also want the best system possible in order to run Half Life 2 with my current budget. So, what do you guys think?
I definitely want to go down the AMD path, but do you think I should go with socket 754 or 939? With my budget should I even go with socket 939 w/ dual channel memory?
I have no idea what way to go with the RAM. I guess that depends on what kind of motherboard you guys suggest... Should I get 1GB of value-type DDR or get 512MB of really good DDR? What brand/etc.?
I want a SATA HD, preferably two drives on RAID0, but I don't think I'll have the cash for that. I'll probably just end up getting one 7200RPM SATA drive and put my 30GB Maxtor as backup on the IDE.
I'm not too sure what way to go with the motherboard either. I kinda want an Asus, but should I go with nForce or a different chipset? I'm gonna need a mobo that has onboard audio and LAN, and hopefully SATA and PCI Express.
I have less than a grand to spend so whatever cash I have left after the stuff mentioned will go into the video card and case/cooling. Should I go with AGP8x or PCI Express? GeForce or ATI for Half Life 2? It really blows though because I'll probably have hardly any money left over for a good card and a nice case with good cooling.
So who thinks they could come up with the best solution for me?
I would really appreciate it if someone could take the time and come up with a system for me that meets my needs. I'll be willing to buy any parts for sale that fit into a suggested system.
Remember, I have about $800-$1,000 and I do a lot of DVD authoring and hopefully can get a system that will run Half Life 2 with decent FPS.
1.1GHz Athlon
256 MB PC133 SDRAM
30GB Maxtor HDD
