I just bought a EPoX EP-8NPA Sli s754 MB & I'm having problems getting the onboard LAN (VITESSE VSC8201RX Gigabit Ethernet PHY) to work with my Linksys Etherfast 5 port workgroup hub (model: EFAH05W).
If I connect the cat5 cable directly from my cable modem to the onboard LAN it works without a problem, but if I try going through the hub I get a constantly flashing "Network Cable Unplugged".
My MB before the EP-8NPA was a ASUS K8N s754 & it worked fine with the hub as well as two other computers that are conected to it. So I'm pretty sure it's not a faulty hub.
* I have tried using all 5 ports on the hub.
* I have tried both the 6.56 & 6.69 nForce4 drivers.
My Computer Setup:
* EPoX EP-8NPA
* AMD 64 3700+ s754
* 2GIG Corsair PC3200
* eVGA 7800GT
* Creative X-Fi Xtreme Music
* Windows XP x64
Link to my Linksys Hub - [ Linksys Hub ]
Link to my Motherboard - [ EPoX EP-8NPA ]
Any suggestions, solution would be greatly appreciated.
Thanks,
P.S. Already sent EPoX support an e-mail.
My Computer Setup:
* EPoX EP-8NPA
* AMD 64 3700+ s754
* eVGA 7800GT
* Windows XP x64
Thanks,
