Help Choosing a MB for an i7-7700k
Martinez
Delving into VR with a Oculus Rift + Touch. I'm looking to upgrade my current setup to an Intel i7-7700k.
I don't OC at all. It will get my current video card (AMD R9 390)
I think I whittled it down to 4 motherboards:
ASRock Z270 KILLER SLI/AC
https://www.newegg.com/Product/Product.aspx?item=N82E16813157746
GIGABYTE GA-Z270-Gaming K3 (rev. 1.0)
https://www.newegg.com/Product/Product.aspx?Item=N82E16813128985
ASUS TUF Z270 Mark 2
https://www.amazon.com/ASUS-TUF-Z270-LGA1151-Motherboard/dp/B01MQTDBOO
MSI Arsenal Gaming Intel (Z270 TOMAHAWK)
https://www.amazon.com/dp/B01N7PCHSU/
I'm trying to keep the price under $150, so any other suggestions would be appreciated.
Kuurus
They are all sexy! Just throw a poke E ball at them and see which one you catch first! lol
ir0nw0lf
I've been eyeing the TUF Z270 Mark 2 board for all the USB ports on the back. I need a minimum of 5 on the back, more is gravy. Plus it looks like one can 3D print a m.2 40mm fan holder that sits above the bottom m.2 slot.
Grimlaking
I've yet to have a problem with an MSI or Gigabyte mobo. (ok my old ASROCK had coil wine after 6 years and could never keep the time even with a good battery but it always ran.,,, does that count?)
I currently have the MSI Z270 Gaming M7 motherboard and it kills it but is above your target price.
I would go with the Gigabyte from your list. Seems to be the most solid choice.
