Help choose: SuperNova 650 P2 or SuperNova 750 G2 or AX760
rsantos97
Need help deciding between these three PSU's for a new build. These are all priced at around $100, give or take $5. The specs are going to be 5820k oc'ed to 4.0 - 4.2 on an EVGA X99 Micro2 matx mobo with 16GBs of DDR4 ram running at 2400. I plan on having one SSD and one HDD. The GPU will be a GTX 970 or better, single card, no OC'ing.
The AX760 is actually $125 up front with a $30 rebate, where as the other two are around $100 without rebate.
Sith'ari
All of them are very good units, whichever you choose is a solid choise.
Personally, i own both the G2 750 and the AX760, and i'm pleased with both of them, but between these 2 i'm more satisfied with the AX760 since it is less noisy in my opinion.
P.S. Also don't forget to look the Corsair RMx750. Very good PSU. I would prefer to buy the RMx instead of the G2 (But the AX760 would still be my 1st choise).
Humpernator
The 650 P2 is plenty enough for your build and OC. You could honestly get away with a 550w but it never hurts to have a little extra room.
mrluckypants96
All of them are very capable units. I'd take the Platinum EVGA for the low upfront cost and high efficiency/low temps.
Redlemur
SUpernovas; either one; evGA P2 and G2 are literally some of the best PSUs you can get using Superflower; and well priced; efficiency will > any corsair; I notice NO noise issues with 650 P2 I got; can't say about g2 but I also had a 550 g2, 2 best PSUs Ive ever had; Corsairs failed me too many times.
