DaRuSsIaMaN
- Apr 22, 2007
Basically, I've never made a forum before, and I'm not familiar with how it works. So, I'm looking for some general as well as specific advice/recommendations.
Right now, I'm thinking that this is what I will do: I'll download phpbb from phpbb.com and design a forum, after which I will find a site which will host my forum for free. Is that a reasonable way to do it? There is an alternative method, right? Could I just choose a template from a site and then get a forum going that way without even needing to use phpbb?
Any recommendations for sites that will do the hosting? I did some searching, and there are apparently plenty of such sites. Any advice on which one I should choose? I want good terms of service, for example. I think one site I saw has it its terms that it will take the forum down if it's inactive for 30 days. That would suck.
Finally, I can't devote a load of time to this. I need a method to make this happen quickly, easily and free (or at least cheap. I could shell out some bucks if I think it is truly worth it).
So, suggestions? Thanks, much appreciated.
