kilgore777
- Sep 12, 2005
Need some advice/feedback….
About 15 minutes into gaming, my screen turned psychedelic and froze. I could only cold boot. On reboot, my LCD screen was blank, but I could tell that Vista(32) had booted normally. I connected an old CRT and it worked fine (using a serial adapter). I tested my LCD on a lappy and it is fine. It works on my Desktop, but only using the serial adapter (the DVI connection won’t work).
I recent clean installed 195.62 drivers from 186.18. In device manager, there was an error message by the driver, so I (clean) reinstalled both 195.62 and 186.18 – neither would install correctly after multiple attempts.
Anyway, I think my VC is foobar…. Is there any way to definitively know? Physical examination showed nothing strange. I have read about problems with 195.62 drivers, some people even claiming they can cause hardware failure (by messing with voltages)…. Is that even possible??
If it is fried, I will be looking for a new one. I want a single slot (non-dual) Video card and I am not tied to NVIDIA.
Any help/suggestions would be greatly appreciated!!
