Help: 3090 install issue?
Light1984
So I just finished my build after getting my dark hero motherboard and this is what the gpu looks like at the back of the BeQuiet 802. Any thoughts why the ports aren't in the middle of the opening and will there be any issue with the outside of the display port connector grounding out on the chassis? I double checked and everything is installed and pushed in all the way.
BinarySynapse
Every card I’ve ever had that has HDMI or DisplayPorts has been like that.
Light1984
Ok. Seems odd to me but I haven't built a computer in 7 years so... Thanks for the quick responses everyone. Fingers crossed it starts.
Krenum
Its fine. You may be used to seeing DVI connections instead of a bank of HDMI & Display Ports. Takes a bit of getting used to if you haven't seen it regularly.
