Heatshrink for fan wires
ldoodle
Hi,
What diameter heatshrink is best for the individual fan wires? I need to solder a custom motherboard header connector.
Thanks
auntjemima
[H]ardness Supreme
Usually you go for one that's slightly larger than the wire. Some heatshrink is a 2:1 and some a 3:1 and I'm sure other ratios too. Some also have a glue type substance inside that more or less waterproofs your wires.
In the end the diameter should be around 1.75:1 of your wire.
magoo
[H]ardForum Junkie
Here's what you need to know.
https://www.cable-sleeving.com/heatshrink
MDPC-X makes the best sleeve and heatshrink you can buy.
I've used this guy's stuff for the past 8 years, back when you had to order it from Germany.
They have US sellers now. Mod-one.com sells MDPC-X stuff here in the US.
