HDD Inaccessible, cant chkdsk but files ARE there... help!
TorxT3D
so this is my 2tb porn drive, and i'll be damn if i let this die without trying...
right now im doing a partition magic partition recovery option on the drive, will take all day, and i think ive done this already in the past and came up with nothing.
photorec sees and recovers the files, i tested this into a temp folder because i dont have an hdd big enough to offload the files onto.
im assuming the partition info is corrupted, not allowing windows to see the files.
just in case this partition recovery option doesnt work, does anyone have tips on repairing the disk structure so i dont have to offload the files? its ntfs btw
thanks!
mwroobel
Try GetDataBack For NTFS, it is great! And just for future reference (because of the politically correct cesspool this world is becoming), it is not your PORN drive, it is your Linux ISO’s drive!
TorxT3D
i used to use getdataback back in the xp days, but its not as robust now.. it only sees and can pull 3 folders
whereas photorec pulls everything but renames all files and also creates alot of junk files that take up space.
so now im looking for another option to fix the actual drive.. so i can retain all files in their respectable folders and filenames
