So I seem to have a HDD failing but have a couple questions about it.
Here is the SMART log of the dying drive:
Here is the SMART of a same model drive that is not dying:
So obviously the reallocated sectors is bad as that keeps going up.
The weird thing and the question I have in regards to ZFS is this though.
The drive says this:
187 is this:
Reported Uncorrectable Errors
The count of errors that could not be recovered using hardware ECC
Yet my zpool status says everything appears fine:
dmesg says this over and over again:
If there are really 585 uncorrectable errors, why isn't ZFS telling me there are checksum errors or something? It doesn't sound like the data I wrote to the array yesterday and today is being written successfully to that drive.
Also, smartctl takes a good 5-6 seconds to respond for this disk while all my other disks respond instantly. Any idea why this is or how it may be related? Isn't is just reading data off the firmware? Is it perhaps because there are 585 ATA Error counts in SMART and it takes awhile to read that data?
Just curious.
I'm ordering a replacement now and should get it Monday to perform the resilver. I'm not too worried since its a 6-disk vdev with 2 parity.
Code:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 083 083 006 Pre-fail Always - 6846404
3 Spin_Up_Time 0x0003 091 091 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 44
5 Reallocated_Sector_Ct 0x0033 089 089 036 Pre-fail Always - 14592
7 Seek_Error_Rate 0x000f 054 054 030 Pre-fail Always - 60133321131
9 Power_On_Hours 0x0032 090 090 000 Old_age Always - 9147
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 48
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 001 001 000 Old_age Always - 585
188 Command_Timeout 0x0032 100 099 000 Old_age Always - 65537
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 066 058 045 Old_age Always - 34 (Min/Max 33/34)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 23
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 252
194 Temperature_Celsius 0x0022 034 042 000 Old_age Always - 34 (0 23 0 0)
197 Current_Pending_Sector 0x0012 089 088 000 Old_age Always - 1880
198 Offline_Uncorrectable 0x0010 089 088 000 Old_age Offline - 1880
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 37404870189985
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 26626247731
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 43462540760
Code:
1 Raw_Read_Error_Rate 0x000f 112 099 006 Pre-fail Always - 48464472
3 Spin_Up_Time 0x0003 094 094 000 Pre-fail Always - 0
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 059 058 030 Pre-fail Always - 12887756042
9 Power_On_Hours 0x0032 094 094 000 Old_age Always - 5312
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 40
183 Runtime_Bad_Block 0x0032 099 099 000 Old_age Always - 1
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 062 053 045 Old_age Always - 38 (Min/Max 38/39)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 39
193 Load_Cycle_Count 0x0032 093 093 000 Old_age Always - 14988
194 Temperature_Celsius 0x0022 038 047 000 Old_age Always - 38 (0 22 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 148442659689107
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 7468891416
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 21496206345
Code:
187 is this:
Code:
NAME STATE READ WRITE CKSUM
nickarray ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
ata-SAMSUNG_HD203WI_S1UYJ1CZ317581 ONLINE 0 0 0
ata-SAMSUNG_HD203WI_S1UYJ1CZ317592 ONLINE 0 0 0
ata-SAMSUNG_HD203WI_S1UYJ1LZ202646 ONLINE 0 0 0
ata-SAMSUNG_HD203WI_S1UYJ1LZ202647 ONLINE 0 0 0
ata-SAMSUNG_HD203WI_S1UYJX0B900055 ONLINE 0 0 0
ata-WDC_WD20EVDS-63T3B0_WD-WCAVY6715008 ONLINE 0 0 0
raidz2-1 ONLINE 0 0 0
ata-ST3000DM001-1CH166_W1F299TA ONLINE 0 0 0
ata-ST3000DM001-1CH166_W1F29PE7 ONLINE 0 0 0
ata-ST3000DM001-1CH166_Z1F10V30 ONLINE 0 0 0
ata-ST3000DM001-1CH166_Z1F2LWDL ONLINE 0 0 0
ata-ST3000DM001-1CH166_Z1F2PL9K ONLINE 0 0 0
ata-ST3000DM001-9YN166_W1F0SQF6 ONLINE 0 0 0
Code:
[345578.245758] sd 1:0:0:0: [sda]
[345578.245759] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[345578.245760] sd 1:0:0:0: [sda]
[345578.245761] Sense Key : Medium Error [current] [descriptor]
[345578.245763] Descriptor sense data with sense descriptors (in hex):
[345578.245764] 72 03 11 04 00 00 00 0c 00 0a 80 00 00 00 00 00
[345578.245768] c4 44 35 c0
[345578.245770] sd 1:0:0:0: [sda]
[345578.245771] Add. Sense: Unrecovered read error - auto reallocate failed
[345578.245773] sd 1:0:0:0: [sda] CDB:
[345578.245773] Read(16): 88 00 00 00 00 00 c4 44 35 88 00 00 01 00 00 00
[345578.245778] end_request: I/O error, dev sda, sector 3292804544
[345578.245791] ata1: EH complete
Just curious.
