Gilbert_pwns
- Nov 13, 2010
So I got a corsair 110i cooler. If I set it up as intended, fans connected to the cooler, the fans stay at 100 percent and I can't do a thing about it. So I opted to connect them on the motherboard. The problem is only the chassis fan 4 can get the fans as low as I need them to be. Also the fans that came with the cooler seem to stop running if I turn them down too low. I'd like all the radiator fans to run constantly at 500 rpm or lower.
I am using the q fan control on my motherboard.
