If it's windows XP, and you can attach the new drive to the old computer, clone it on the old computer, boot the old computer with the new drive, run sysprep, remove new drive from old computer and install it into new computer and boot it up.
If ahci is not enabled on the old machine, or it doesn't have it, you will probably have to turn off ahci on the new machine otherwise it may just blue screen and keep rebooting.
The above is the process I used when upgrading my pc when I was using windows xp.
Windows 7 on the other hand has boot up with no issues on completely different hardware the dozen or so times I have tried it.
But ahci has to be disabled on the new machine if ahci was off or not available on the old one.
It is win 7. Ill just image it and see how Windows 7 handles it.
