So...people de-lidding, but no one pushing their chips to see if they can get a better overclock. WTF is wrong with this picture? lol
I've had a peek at a few ivy delidding threads... why are people putting the IHS back on instead of adding a shim and doing it old school style? Is the IHS really needed to increase the surface area?
If you guys find any overclocking attempts on delidded chips drop a link please. I want to know if delidding increases maximum overclocks. My prediction is that it won't most of the time, but I wanna see the data.
Thanks for the links.
i've never heard of delidding, why do this?
The post right above you doesn't explain it well enough? Or did you even look
i delidded my 4770K using the vice + hammer method from overclock.net. I was really surprised how easy it was. A couple light hits (nothing more than the weight of the hammer from about 6 inches) and the adhesive broke loose enough to lift the chip off the ihs. Personally i don't trust myself enough to do the razer method, no way im steady or patient enough for that.
I put ceramique on it temporarily and saw temps drop about 15 deg. CLU is on the way and should be here today or tomorrow.
Before delid:
4.2ghz @ 1.25v - around 92Deg in Prime
After delid:
4.6ghz @1.32v - around 85 Deg in Prime
Im still playing with the overclock and will see how much farther i can go with the CLU. My chip seems pretty finicky though, i can get up to 4.5 with 1.26v but anything over 4.5 seems to require a massive jump in volts so im not sure at the moment what i will keep it at.
