Hardware to accept WiFi and send out ethernet cable?
Discussion in 'Networking & Security' started by mcravenufo, Apr 8, 2010.
  1. mcravenufo
    mcravenufo Ravenufo's Macs
    5,091
    Feb 28, 2001
    I just bought the Verizon Wireless MiFi2200 Intelligent Mobile Hotspot. Is there a product that can connect to this through WiFi and allow me to connect hardwired computers? I guess like a reverse Wireless Access Point...
  2. p0lish
    p0lish Gawd
    563
    Sep 11, 2002
  3. awesomo
    awesomo Gawd
    528
    Mar 20, 2010
    Sure there are. It's called a wireless bridge although most manufacturers like to call it a wireless gaming adapter. But I wouldn't buy any of them for stability reasons.
    This:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16833124190&Tpk=wrt54gl
    Running this:
    dd-wrt.com
    Will be a nice 5 port wireless bridge and stable as hell. I have been running these for years without ever having to reset them. Before you go shooting down the idea with it being too complicated, I assure you, a complete noob could knock this out in a few hours if they just followed the directions.
  4. mcravenufo
    5,091
    Feb 28, 2001
    I was under the assumption that those only broadcast wireless to receiving computers not receiving wireless from another WiFi wireless and sending out wired.
  5. awesomo
    awesomo Gawd
    528
    Mar 20, 2010
    Out of the box you are right, but running dd-wrt changes all of that and allows it to be a wireless 5 port switch.
  6. mcravenufo
    5,091
    Feb 28, 2001
    Ah, I see. I posted a little too quick before reading about dd-wrt. Very cool. Thanks for the info!
  7. keenan
    keenan 2[H]4U
    2,695
    Aug 5, 2009
    dd-wrt is a great option. I've also been successful with the tiny, cheap single-port ASUS WL-330gE that can do it out of the box.
  8. mcravenufo
    5,091
    Feb 28, 2001
    So I'm looking through the build features and can't determine what I want to do is called. What do I look for? I want to know if I should install the standard build because for that Linksys I need to start with the mini.
  9. awesomo
    awesomo Gawd
    528
    Mar 20, 2010
  10. mcravenufo
    5,091
    Feb 28, 2001
    Thanks, I really appreciate it. I will be setting this up tomorrow on the Linksys.
  11. InvisiBill
    InvisiBill 2[H]4U
    2,608
    Jan 2, 2003
    FYI, a Cradlepoint router like p0lish suggested would allow you to plug the MiFi's USB into the Cradlepoint and it would act like a regular WAN connection (just like plugging a cable or DSL modem into a regular router). The Cradlepoint then provides internet access through the MiFi to your entire LAN, just like a regular router would share your cable/DSL. The MBR900's MSRP is $150.
    Using a wireless bridge, the MiFi itself will be acting as the router for any devices connected to your LAN (via the MiFi's wireless or the wireless bridge). The bridge is essentially just a wireless-to-wired adapter.
